webcam issues
Forum for the Minix Neo X5 set top box.
webcam issues
Postby pockmon » Sat Dec 29, 2012 8:50 am
I have a logitech C270, which had worked fine with X5. However, after re-flashed, Skype didn't work. I managed to make it work by toggling sound device settings. If you have issues with webcam, try this to see if you have the luck.
In Settings/Sound, select "Sound Devices Manager". Under "audio input", two options are listed. My system selected the "USB Device 0x..." by default. Select the other one, RK29_RT563. Then select back. Then everything works fine. I would guess the action reinitialize the device driver, which does the magic.
Return to “Neo X5”
